tonyhorse
Jun 30, 2020Follower
Download speed 8 times lower than upload speed
I have an extremely strange problem that I cannot solve and can only conclude that there is a hardware problem. In short I have an FTTC connection via a Draytek 2860 and I get around 70mbps/18mbps do...
Jul 07, 2020Guru - Experienced User
Your ISP modem already has built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I recommend trying AP mode first...
