jcricket73
Oct 26, 2019Follower
Download speeds at 1/10th non-Orbi Wifi router since latest firmware
I had to replace a totally dead 2-month RBR50 (no amount of rebooting/factory resetting fixed anything). New RBR50 and 2 satellites arrive and get installed, all the connections work ok (can connect ...
Oct 26, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
