AngelicRocker
Dec 05, 2020Aspirant
Drastically reduced internet speed at night (RBR50)
So I bought and installed my Orbi system in January 2020 and loved it immediately, solved nearly all of my household's internet issues at the time. Cut to September 2020 and we have a Spectrum techni...
Dec 05, 2020Guru - Experienced User
Has a power off for 1 minute then back on been performed since last update?
V4 isn't the mode recent:
You can try this or I would downgrade to v16. What I currently use on my RBK50 series.
AngelicRocker
Just did a 1 minute power off on the modem and router and manually updated the router to v2.7.1.60. Have not done another power cycle after update (only the reboot it did itself after installing) nor have I done a full factory reset (trying to avoid that if at all possible).
Again after rebooting both the wired and wireless signals test properly though I'm expecting it to drop any minute.
- FURRYe38Dec 05, 2020Guru - Experienced User
Try the reset if it happens...
- AngelicRockerDec 06, 2020Aspirant
Factory reset done. Unfortuntately made zero difference.
