siquenique
Sep 25, 2022Aspirant
Drop on speed with rbs40v
I am having issues with speed when connected to the RBS40V. My setup has the router, a rbs20 satellite connected to the router and a RBS40V connected to the satelitte in daisy chain. All the option I ...
Sep 25, 2022Guru - Experienced User
what speed do you get hardwired into the RBS40V?
That'll be the key as that'll tell you what speeds you're getting out of the backhaul.
- siqueniqueSep 25, 2022AspirantHow can I check that?
- plemansSep 26, 2022Guru - Experienced User
hardwire a pc/laptop into the RBS40V and run a speedtest on the hardwired device
