siquenique
Sep 25, 2022Aspirant
Drop on speed with rbs40v
I am having issues with speed when connected to the RBS40V. My setup has the router, a rbs20 satellite connected to the router and a RBS40V connected to the satelitte in daisy chain. All the option I ...
Sep 25, 2022Guru - Experienced User
what speed do you get hardwired into the RBS40V?
That'll be the key as that'll tell you what speeds you're getting out of the backhaul.
siquenique
Sep 26, 2022Aspirant
How can I check that?
- plemansSep 26, 2022Guru - Experienced User
hardwire a pc/laptop into the RBS40V and run a speedtest on the hardwired device
