Yld2rob
Oct 20, 2016Luminary
Dropcam issues and separate SSID's for 2.4 and 5.0 GHZ
I have an issue and also a question. I have over 50 devices, phones, ipads,compters, smarthome hubs and devices(which all stay connect the the network). I also have two Dropcam cameras which can conn...
Skrymir
Oct 20, 2016Guide
Yld2rob,
The Dropcam disconnect problem is a known issues. You'll need to disable implicit breamforming in the Orbi config to fix the problem.
-Josh
Yld2rob
Thanks. I thought I was going crazy. So Netgear is working on a fix? Beamforming is a feature that some of my other devices use and would like them to take advantage of.
