GG260
Dec 05, 2017Initiate
Dropped devices
Bought a new unit with satellite 2 weeks ago. Hook up was pretty simple. First of all, I’d like to be able to choose which bandwidth each device uses. It appears it auto senses but I’d rather have th...
st_shaw
Dec 05, 2017Master
The following factors might be contributing to what you are seeing:
1) iOS devices are programmed to power-off WiFi 30 seconds after the screen goes dark. This is normal. You can test this by pinging your device from another device. You will see the pings stop 30 seconds after the screen goes off. What might be abnormal in your case is how long it takes the iPad to reconnect, as this should happen very quickly. You could try forgetting the Orbi WiFi connection on your iPad and re-adding it.
2) Many TVs (including the ones I own) will power off the network connection when the TV is OFF. In the case of my Panasonic TV, this applies to both WiFi and wired connections. In my case, the only solution is to wait 10-15 seconds after powering the TV ON before trying to access any TV apps that use Internet. For example, if I access VieraCast sooner than that, the TV asks me to go throught the entire network setup procedure, even though the TV already has the SSID and password stored in the settings.
- GG260Dec 06, 2017Initiate
Thanks but it’s dropping the iPad connection is dropping while in use
