LewBob's avatar
LewBob
dropped phone calls on voice over wifi
My wife and I both have Motorola phones (mine is a G6). I have had the original Orbi for a few years. We moved from Verizon to T-Mobile a few years ago and got these phones. We are in a poor reception area so we use wifi for our calls. I can't remember when it started, but both of us are losing calls and/or have calls fade in and out.
Any ideas on what could be causing it? Anything in the Orbi settings? I tried turning off daisy chain (I have 2 satellites) and fast roaming. Firmware is V2.5.1.8
  • plemans's avatar
    Try updating to the 2.5.1.32 firmware for the router and satellites. Make sure to update the satellites first.
    What modem/gateway is it connected to?
    • LewBob's avatar
      LewBob
      Thanks for the quick response. I upgraded firmware last night. No luck. Sitting at the kitchen island today, with a terrific,  line of sight, connection to the router I made a call. The person on the other end couldn't hear me and he was breaking up. I tried again, same thing. I turned off wifi and made the call again and it worked fine.
      We are with Century link with a Zyxel modem.
      • plemans's avatar
        which zyxel modem?
        And something to check is what api server you're using for the wifi calling. I've had the wrong server set on my phone for the wifi calling and it wouldn't work.
