Andrew1977
Jan 14, 2019Guide
Dropped WiFi calls on iPhone X iOS 12 ATT with Orbi RBR50
I’m experiencing dropped WiFi calls with my iPhone X. The calls will typically last only a few seconds before the call fails. I had been using the WiFi calling on my Orbi RBR50 and 1 satellite for ...
ekhalil
Jan 15, 2019Master
Andrew1977 wrote:
- ......Orbi sits in DMZ of ATT Uverse router. I had ATT technician onsite to check everything and they found no issues.........
For the sake of testing only, have you tried to remove the DMZ routing and see if that has something to do with your issue?
It's worth testing, although that you can't keep this setting as this will cause double routing and double NAT in your network.
What is the model of the router? there is may be a way to bridge the router instead.
