manxdoc
May 27, 2020Guide
Dropped WiFi connection
Hi everyone! My first post. I have bought a kit consisting of a RBR50 router and 2 x RKS50 satellites. At present I'm only using one of the satellites as tne 2nd is not needed right now. The route...
- May 27, 2020
Hi FURRYe38. Thank you for the very quick reply
The firmware of router and satellites has been updated. The router version is V2.5.1.8
I am connected to Gigaclear and the provided modem is a DKT Comega (no further info on it)
Channels: 2.4GHz Auto (I tried changing this to 6 before without improvement)
5GHz channel 36
Neighbours (x2) I would say about 100 meters away, very rarely I can faintly receive the wifi signal of one of them.
WMM is enabled
I had MIMO and Beamforming enabled and I was having issues so tried without. WIll try re-enabling them again
Where do I find "IPv6 and 20/40Mhz Coexistence" please?
Thank you again
May 27, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Farther distance can be done as well. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
