manxdoc
May 27, 2020Guide
Dropped WiFi connection
Hi everyone! My first post. I have bought a kit consisting of a RBR50 router and 2 x RKS50 satellites. At present I'm only using one of the satellites as tne 2nd is not needed right now. The route...
- May 27, 2020
Hi FURRYe38. Thank you for the very quick reply
The firmware of router and satellites has been updated. The router version is V2.5.1.8
I am connected to Gigaclear and the provided modem is a DKT Comega (no further info on it)
Channels: 2.4GHz Auto (I tried changing this to 6 before without improvement)
5GHz channel 36
Neighbours (x2) I would say about 100 meters away, very rarely I can faintly receive the wifi signal of one of them.
WMM is enabled
I had MIMO and Beamforming enabled and I was having issues so tried without. WIll try re-enabling them again
Where do I find "IPv6 and 20/40Mhz Coexistence" please?
Thank you again
manxdoc
May 27, 2020Guide
5GHz channel 36
WMM is enabled
Thank you again
May 28, 2020Guru - Experienced User
This DKT a fiber ONT? Have a built in router that you know of?
Try channel 11.
Test the wifi connetion with the RBS turned OFF.
Under Advanced Tab/Advanced Settings/Wireless Settings
