manxdoc's avatar
manxdoc
Guide
May 27, 2020
Dropped WiFi connection
Hi everyone! My first post. I have bought a kit consisting of a RBR50 router and 2 x RKS50 satellites. At present I'm only using one of the satellites as tne 2nd is not needed right now. The route...
  • manxdoc's avatar
    manxdoc
    May 27, 2020
    Hi FURRYe38. Thank you for the very quick reply
    The firmware of router and satellites has been updated. The router version is  V2.5.1.8
    I am connected to Gigaclear and the provided modem is a DKT Comega (no further info on it)
    Channels: 2.4GHz   Auto  (I tried changing this to 6 before without improvement)
    5GHz  channel 36
    Neighbours (x2) I would say about 100 meters away, very rarely I can faintly receive the wifi signal of one of them.
    WMM is enabled
    I had MIMO and Beamforming enabled and I was having issues so tried without. WIll try re-enabling them again
    Where do I find "IPv6 and 20/40Mhz Coexistence" please?
    Thank you again
