manxdoc
May 27, 2020Guide
Dropped WiFi connection
Hi everyone! My first post. I have bought a kit consisting of a RBR50 router and 2 x RKS50 satellites. At present I'm only using one of the satellites as tne 2nd is not needed right now. The route...
- May 27, 2020
Hi FURRYe38. Thank you for the very quick reply
The firmware of router and satellites has been updated. The router version is V2.5.1.8
I am connected to Gigaclear and the provided modem is a DKT Comega (no further info on it)
Channels: 2.4GHz Auto (I tried changing this to 6 before without improvement)
5GHz channel 36
Neighbours (x2) I would say about 100 meters away, very rarely I can faintly receive the wifi signal of one of them.
WMM is enabled
I had MIMO and Beamforming enabled and I was having issues so tried without. WIll try re-enabling them again
Where do I find "IPv6 and 20/40Mhz Coexistence" please?
Thank you again
manxdoc
May 29, 2020Guide
Hi
This DKT a fiber ONT? Have a built in router that you know of?
The DKT Comega is a fiber modem. https://dktcomega.com/product/juma-series/
Yes
Try channel 11.
Done
I unticked 20/40 coexistence: correct?
I moved the RBS to the first floor about 10-12 meters away. When I now check the "attached devices", the "Backhaul status" of the RBS
is reported as "Poor"
As the issue is intermittent and difficult to know if the connection is working well or we just missed it dropping at times, is there a way to tell by logging into the router?
Thanks once again.
Jun 01, 2020Guru - Experienced User
How has the system been working?
Ok, of the status is POOR, try moving the RBS just a bit closer, 1 foot at a time until the status changes to GOOD.
- manxdocJun 03, 2020Guide
Hi. I definitely think that the changes you suggested have helped.
I will experiment further with the positioning of the RBS to the router.
Thank you very much for your good advice, really appreciated!
- FURRYe38Jun 03, 2020Guru - Experienced User
Good to hear. Hope it keeps working well for you. Mark your thread as solve when you think it works fully so others will know.
Enjoy. :smileywink:
