klp8466
Apr 10, 2018Guide
Dropping Connection
My model number is not listed here. Assuming, that's because I bought the router/satellite at Costco 'Orbi Mini RBR20 AC2200'. First night and everything dropped several times and I decided to go ...
klp8466
Apr 10, 2018Guide
I have TWC/Spectrum ARRIS TG1672G 300 Mbps. We had a netgear and the only issue I had was our sons PS4 after years of using it and everything else works fine. The netgear we have has less coverage then the Orbi Mini. So I was thinking if we upgraded perhaps it would work and it's actually worse, as it drops everything. So I'm sure something is not set up right. The orbi router we had on the main level of our home as that is where most of us use your computers and then the satellite in the basement for the gaming systems. The router would go white then at somepoint show no color and the sateltte would show light blue and lose its color as well. I assumed that was due to dropping the connection.
Retired_Member
Apr 10, 2018no color is good (if at one point it was blue). it basically means that it's running and all is well.
- klp8466Apr 10, 2018Guide
Ok thank you, now I just need to figure out why it drops every hour....
- Retired_MemberApr 10, 2018
to add....the router should pulse white then go out.
the sat(s) should pulse white, then may go pink....but should end up blue....then go out.
Yes, it did all that. Was running good and then after that started dropping the connection on the main level and basement. So somethings not right for it to be dropping. I will call tonight and see if there is something in the settings. I would think since I just set it up last night it would not be the settings, but who knows.
the next thing to consider is what firmware version are you running?
Lots of discussions here as to the problems NG has had with firmware.
