jrw1881's avatar
jrw1881
Guide
Feb 20, 2021
dropping connection
Hello everyone!
I have been using the Orbi RBR50 since 2018 and it has been a doing a great job for a 6000 sq. ft. house (3 floors). I have had an occasional reset (unplug and restart) and I was back up and running. I have just started to have problems with the system dropping its connection every few minutes. Sometimes it comes back up by itself and other times I must do the power off thing and reboot. I usually get back up and running with no problems. But it has become persistant in dropping out and staying our for awhile.??
I read in this forum that years ago they had this issue but was not able to locate and discussion in 2021 for this problem so here goes?
I have a Orbi RBR50m with two other satellites. I used to have the wire run from the cable modem to a TP Link wired router with 9 ports. I have removed the TP Link router and run the modem (Arris 6141) directly to the RBR50 wireless router, the I run a connection to the 8 port switch for some direct wired devices in my house. Everything seemed to work fine until it(RBR50) started dropping its connection and rebooting only to have it go out again and again?
Using RBR50 + 2 sat.
Firmware is latest V2.7.2.104
Using cable codem
Can anyone tell me how to fix this problem? I have not done a "factory reset" on the router as of yet but will do this as a last resort if the problem continues. Any suggestions would be apprecitated>  Thanks
  • CrimpOn's avatar
    CrimpOn
    When this happens, does the Orbi log file (in the web interface, Advanced Tab, Administration, Logs) show the Orbi has actually rebooted (log entry of "Initialized") or does it show "Internet Disconnected"?
    • jrw1881's avatar
      jrw1881
      Guide
      I have never checked? Will try the web interface as I suggest and let u know. Dropped once today and had to reboot a satellite but internet came back on its own and sat reconnected.
      • vajim's avatar
        vajim
        Master
        rool it back to a previous release
        go to downloads (above) enter your model number
    • vajim's avatar
      vajim
      Master
      here's your problem:  Firmware is latest V2.7.2.104
      Get rid of it
