jrw1881
Feb 20, 2021Guide
dropping connection
Hello everyone! I have been using the Orbi RBR50 since 2018 and it has been a doing a great job for a 6000 sq. ft. house (3 floors). I have had an occasional reset (unplug and restart) and I was ...
vajim
Feb 22, 2021Master
Ha_Ku_Na wrote:1. Ignore vajim posts. This is the most important suggestion.
2. Reset the Satellite.
If this does not help.
1. same as above
2. power off satellite
3. remove satellite from vonfig via web admin interface
4. reset satellite
5. add satellite via web admin interface
I run the latest fw without any issues. 1xRBR50, 2xRBS50 via WIFI backhaul, 1xRBS wired behind a switch.
rool it back to a previous release
go to downloads (above) enter your model number
this is another case of "well it worked for me so it has to work for you ".....NOT
jrw1881
Feb 22, 2021Guide
Ok just found out I can log into orbi on my computer? Think I just forgot about it!
Everything looks great now but what should I monitor should this go out again? Is there a long where I can see where the problem is with the connection? Like is it the router or my internet provider causing the problem?? Any guidance would be appreciated.
- Ha_Ku_NaFeb 22, 2021Luminary
Advanced –> Administration –> Logs
