Tdig27
Oct 07, 2020Aspirant
dropping wired connections constantly
My Orbi RBR20 system worked great for over a year. Just recently, it seems it loses the wired connection every few minutes. I have a netgear cm1000 router into the Orbi router with the other port feed...
Oct 08, 2020Guru - Experienced User
Take the RBS to the same room as the RBR, use a ethernet patch cable. Wirelessly connect the RBS to the RBR first. Once it's connected and BLUE appears on the top of the RBS, connect the ethernet cable to the RBR. Check the RBRs web page for status on the connection.
Tdig27
Oct 08, 2020Aspirant
Sorry- I should have been more clear. The connection between the RBR and the RBS is stable, whether wired or wireless. The other devices that are connected to to the switch are losing their connection to the internet.
Firmware on the RBR and RBS is 2.5.1.16.
It seems as though the router is the issue. I temporarily swapped it out for an old wireless-g router I had kicking around to make determine whether it could have been modem or ISP related and all connections are stable.
- Tdig27Oct 08, 2020Aspirant
I re-read the post and understand why you asked. Here is the additional clarity I missed in the original post:
The backhauled RBS remains connected to the RBR, that connection is ok. However, it is NOT connected to the internet. So, if a device is connected to the network via that satellite, it will not have an internet connection. Any wireless devices connected to the RBR directly, have a stable connection and experience no issues, even when the wired devices are losing their connection. For example, as I type this on a computer that is hardwired, it has continuously dropped and reconnected while the Sonos One while someone in the room next to me is gaming without any issues via the wireless connection.
Thanks again!
- FURRYe38Oct 08, 2020Guru - Experienced User
Try setting up IP address Reservations for your devices...
Has a factory reset and setup from scratch been performed since last update?
