Tdig27
Oct 07, 2020Aspirant
dropping wired connections constantly
My Orbi RBR20 system worked great for over a year. Just recently, it seems it loses the wired connection every few minutes. I have a netgear cm1000 router into the Orbi router with the other port feed...
Tdig27
Oct 08, 2020Aspirant
Sorry- I should have been more clear. The connection between the RBR and the RBS is stable, whether wired or wireless. The other devices that are connected to to the switch are losing their connection to the internet.
Firmware on the RBR and RBS is 2.5.1.16.
It seems as though the router is the issue. I temporarily swapped it out for an old wireless-g router I had kicking around to make determine whether it could have been modem or ISP related and all connections are stable.
Tdig27
I re-read the post and understand why you asked. Here is the additional clarity I missed in the original post:
The backhauled RBS remains connected to the RBR, that connection is ok. However, it is NOT connected to the internet. So, if a device is connected to the network via that satellite, it will not have an internet connection. Any wireless devices connected to the RBR directly, have a stable connection and experience no issues, even when the wired devices are losing their connection. For example, as I type this on a computer that is hardwired, it has continuously dropped and reconnected while the Sonos One while someone in the room next to me is gaming without any issues via the wireless connection.
Thanks again!
