rix0rrr
Feb 12, 2018Star
Drops network every 30 seconds for 5 seconds
My Orbi is dropping network connectivity for 5 seconds just about every 30 seconds. It's not exactly 30 seconds, but it does occur very regularly, definitely every minute. I'm on version 2.1.2.18...
- Feb 17, 2018
Downgrading to V2.0.1.4 fixed it for me.
rix0rrr
Feb 12, 2018Star
Here's an interesting bit of info:
I found somewhere on the forum that you can go to a special url, http://<ip-of-router>/debug.htm, and from there I found I can ENABLE TELNET ACCESS!
After logging in on the box, I noticed a process called something like "miniupnpd" (or similar, it's hard to check now) eating a lot of CPU. After killing it, I still see occasional lag spikes of 100-200ms, but the drops are gone!
- rix0rrrFeb 13, 2018Star
Okay so killing miniupnpd doesn't fix it. The hangups occasionally still happen, but less frequently (once every hour or so).
Dropping packets/high latencies seem to be accompanied by high CPU usage on the Orbi.
- webminsterFeb 13, 2018Luminary
Given your discovery, do you have UPnP enabled or disabled in the Web UI? Advanced Setup. Causes issues for many people.
- rix0rrrFeb 13, 2018StarThe UPNP setting appears greyed out for me, probably because I have the device in AP mode... :(
