rix0rrr
Feb 12, 2018Star
Drops network every 30 seconds for 5 seconds
My Orbi is dropping network connectivity for 5 seconds just about every 30 seconds. It's not exactly 30 seconds, but it does occur very regularly, definitely every minute. I'm on version 2.1.2.18...
- Feb 17, 2018
Downgrading to V2.0.1.4 fixed it for me.
rix0rrr
Feb 12, 2018Star
Here's an interesting bit of info:
I found somewhere on the forum that you can go to a special url, http://<ip-of-router>/debug.htm, and from there I found I can ENABLE TELNET ACCESS!
After logging in on the box, I noticed a process called something like "miniupnpd" (or similar, it's hard to check now) eating a lot of CPU. After killing it, I still see occasional lag spikes of 100-200ms, but the drops are gone!
rix0rrr
Feb 13, 2018Star
Okay so killing miniupnpd doesn't fix it. The hangups occasionally still happen, but less frequently (once every hour or so).
Dropping packets/high latencies seem to be accompanied by high CPU usage on the Orbi.
