rix0rrr
Feb 12, 2018Star
Drops network every 30 seconds for 5 seconds
My Orbi is dropping network connectivity for 5 seconds just about every 30 seconds. It's not exactly 30 seconds, but it does occur very regularly, definitely every minute. I'm on version 2.1.2.18...
- Feb 17, 2018
Downgrading to V2.0.1.4 fixed it for me.
rix0rrr
Feb 13, 2018Star
The UPNP setting appears greyed out for me, probably because I have the device in AP mode... :(
rix0rrr
Feb 17, 2018Star
- rix0rrrApr 08, 2018Star
And my Orbi rolled forward again to V2.1.3.4 and now it's broken again.
Going to roll back and disable updates.
NetGear, you're not very good at software!
- PyroDogApr 08, 2018Apprentice
I've been through your exact same experience. No one from Netgear has been able to address this concern directly. My permanent solution has been to rollback all the way to V2.0.0.74 and use my main router's firewall to block the Orbi units from updating.
- FURRYe38Apr 08, 2018Guru - Experienced User
What is the problem your having? Please give details.
Hard to know whats really wrong.
PyroDog wrote:I've been through your exact same experience. No one from Netgear has been able to address this concern directly. My permanent solution has been to rollback all the way to V2.0.0.74 and use my main router's firewall to block the Orbi units from updating.
Have you factory reset the router and satelllites and set up from scratch, after the system was updated to v2.1.3.4? This needs to be done when using this version of FW.
rix0rrr wrote:And my Orbi rolled forward again to V2.1.3.4 and now it's broken again.
