eyrieowl
Mar 20, 2021Tutor
DST Fix Orbi Internet Drop
Created the post to bring the fix to the top level. tl;dr if you turn off "Automatically adjust for daylight savings time" (under Advanced -> Administration -> NTP Settings) and put in a server under...
Mar 20, 2021Guru - Experienced User
Was Traffic Meter in use by chance here? Someone reported that they were notificed by NG that they found the cause of these issues was the use of Traffic Meter. Something to be aware of. I'm using v104, DST ensbled and NG time server and not see any issues on the RBK50 system. Traffic Meter is disabled on mine.
- eyrieowlMar 20, 2021TutorInteresting. It *is* enabled, with no limit. Perhaps that works too? I'm not inclined to try at the moment, but I'd be willing to believe that's an alternate solution.
- FURRYe38Mar 20, 2021Guru - Experienced User
If it's enabled then disable it. Someone else reported that they contacted NG support and they told them this seems to be a TM issue. I've not used TM at all and havn't noticed problems with my RBK50, DST is enabled on mine.
