eyrieowl
Mar 20, 2021Tutor
DST Fix Orbi Internet Drop
Created the post to bring the fix to the top level. tl;dr if you turn off "Automatically adjust for daylight savings time" (under Advanced -> Administration -> NTP Settings) and put in a server under...
eyrieowl
Mar 20, 2021Tutor
Interesting. It *is* enabled, with no limit. Perhaps that works too? I'm not inclined to try at the moment, but I'd be willing to believe that's an alternate solution.
Mar 20, 2021Guru - Experienced User
If it's enabled then disable it. Someone else reported that they contacted NG support and they told them this seems to be a TM issue. I've not used TM at all and havn't noticed problems with my RBK50, DST is enabled on mine.
