eyrieowl
Mar 20, 2021Tutor
DST Fix Orbi Internet Drop
Created the post to bring the fix to the top level. tl;dr if you turn off "Automatically adjust for daylight savings time" (under Advanced -> Administration -> NTP Settings) and put in a server under...
Blanca_O
Mar 24, 2021NETGEAR Employee Retired
Hi eyrieowl
Engineering was able to discover the cause of this issue and they are working on a fix in regards to the disconnections.
The issue comes from Traffic meter while daylight saving is enabled. The quick workaround is to disable the traffic meter.
To disable traffic meter:
Access orbilogin.com > go to ADVANCED Tab > Advanced Setup > Traffic Meter and uncheck Traffic Meter
Blanca
Community Team
