AdrianM
Dec 13, 2018Tutor
DTIM Beacon Interval
I can only assume that there is no way to alter the Beacon Interval for Orbi - given the number of times this question arises from users of other Netgear WiFi routers. Or am I being too pessimistic? ...
RocketSquirrel
Dec 15, 2018Luminary
There's a configuration variable in NVRAM.
# config show | grep -i dtim
wl_dtim=1
You can telnet into the Orbi and change it.
# config set wl_dtim=4
# config commit
I don't know whether a change to the main Orbi will propagate to satellites or whether you'd need to telnet into each unit. Whether changing this variable will have the desired effect is left as an exercise for the reader.
RocketSquirrel
Dec 18, 2018Luminary
AdrianM - did you try this and did it work?
