JohnHighrock's avatar
JohnHighrock
Duplicate a RBK50 installed solution
Hello,
Already equipped with a rbk50 system (router + 1 satellite) I would like to extend my wifi coverage.
Can I install a second RBK50 system (router+satellite) with the same wifi name to make this extension.
Thank you 😉
  • You can install the RBS from the 2nd system. The RBR from the 2nd system can only work in router mode or in AP mode. Not as a satellite.
    JohnHighrock wrote:
    Hello,
    Thank you 😉
