Mr-Wednesday
Jun 13, 2017Tutor
Duplicate IP Addresses on Orbi Router and Satellite
Okay, so my "Attached Devices" on both my Orbi Router (RBK50) and my Orbi Satellite (RBS50) both show the some of the same IP addresses. What gives? It's difficult to tell which device (Router or S...
- Jun 15, 2017
The router shows all connected devices in the network when you connect to the satellite you see whats just connected to that unit.
DarrenM
DarrenM
Jun 15, 2017Sr. NETGEAR Moderator
Hello Mr-Wednesday
You can log into each satellite by using there ip address this will tell you what devices are connected to it.
DarrenM
Mr-Wednesday
Jun 15, 2017Tutor
Well that's the point - i see the same IPs when I login to both routers.
For example, when Iogin into the router I see these IPs:
192.168.200.108
192.168.200.110
192.168.200.117
When I log into the satellite, I see these IPs:
192.168.200.108
192.168.200.117
So which router are 192.168.200.108 and 192.168.200.117 really assigned to?
- DarrenMJun 15, 2017Sr. NETGEAR Moderator
DarrenM
- Mr-WednesdayJun 15, 2017Tutor
Thank You! I'm glad I finally have some clarification.
