chrislfc11
Jul 23, 2018Aspirant
During WAN Outage no connectivity to LAN
I recently experienced a WAN outage from my ISP, during this time ORBI was disconnected from the internet. My device (cell phone) showed connected to my Orbi router and LAN network but i could not na...
Jul 23, 2018Guru - Experienced User
Hopefully something will fix this. Others haven't reported anything like this...
I know when I was setting up my friends RBK50, I had access to the routers web page while I was setting it up, even with out the modem connected...
One thing you can do even if you do fix this, get you a 1Gb Non managed switch to put in behind the router. These are good to have anyways, then connect up most of your wired devices to it. Regardless of the modem or router operations, you'll have network access to resources thru the switch. I use a 24port behind mine, Also have a couple of others daisy chained.
chrislfc11
I have a slower 5 port switch behind the router that i use to connect devices that dont need the high speeds such as Sonos, etc. But in order to connect to them i would have to go through the router either Wifi or hardwired, which i also could not connect to the devices on the switch.
