markaustin
Jan 10, 2017Guide
Dynamic DNS hostname registration failure when using dyn.com
Just purchased an Orbi to replace my previous gen Netgear Router. I manually entered all the same settings (that were applicable) from the old router. However, DDNS does not seem to work whatsoever...
DarrenM
Feb 06, 2017Sr. NETGEAR Moderator
Hello anschmid
You may have to go to the NO-Ip website and make the account there and then try it.
DarrenM
anschmid
Feb 06, 2017Apprentice
Darren, thanks!
I actually tried that and went to NO-IP website. It recognizes that there is an account (email) and my password works too but once I get in it tells me the account has never been activated and only allows me to resend the activation email which as before never shows up?
Is there anything special about the Netgear NO-IP accounts that would prevent the activation email to be send out or is this a NO-IP problem?
- DarrenMFeb 07, 2017Sr. NETGEAR Moderator
Hello anschmid
Not that I am aware of it should send one to you may want to ticket No-Ip support to help with that.
DarrenM
- JMU1998Feb 07, 2017Luminary
can please notify Netgear Engineering about the DynDNS issue so they can get a fix in the firmware for it. I also have a paid subscription and would like to use like others have mentioned.
- anschmidFeb 07, 2017Apprentice
DarrenM, I just went to open a support ticket with NO-IP and found this on their open a ticket page:
We're currently experiencing issues with icloud.com and me.com receiving emails. If you have not received your email please contact our Customer Success team and they will be glad to assist you.
I guess that explains it for me as I am using iCloud. Hope they can solve it soon!
Hello JMU1998
I did check with engineering and they are fixing the issues DYNDNS accounts not working in the next firmware which is coming soon.
DarrenM
