markaustin
Jan 10, 2017Guide
Dynamic DNS hostname registration failure when using dyn.com
Just purchased an Orbi to replace my previous gen Netgear Router. I manually entered all the same settings (that were applicable) from the old router. However, DDNS does not seem to work whatsoever...
anschmid
Feb 07, 2017Apprentice
Darren, thanks!
I actually tried that and went to NO-IP website. It recognizes that there is an account (email) and my password works too but once I get in it tells me the account has never been activated and only allows me to resend the activation email which as before never shows up?
Is there anything special about the Netgear NO-IP accounts that would prevent the activation email to be send out or is this a NO-IP problem?
DarrenM
Feb 07, 2017Sr. NETGEAR Moderator
Hello JMU1998
I did check with engineering and they are fixing the issues DYNDNS accounts not working in the next firmware which is coming soon.
DarrenM
