Duncan9988's avatar
Duncan9988
Dyson Fan stays connected but doesn't show on device list & gets stuck "updating" with HomeBridge
Dyson Fan stays connected but doesn't show on device list & gets stuck "updating" with HomeBridge. If i kill the power to the Dyson and turn it back on gain it connects fine and works in HomeKit and HomeBridge again, then half an hour later the same thing happens again, the Dyson Link app works so there is a connection to the WiFi but no device shows on the Attached Devices list and HomeKit/HomeBridge gets stuck on Updating again.
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded?
    What is this HomeBridge device? Contact the Mfr of Dyson for help and information on it's updating process and features.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
