Maomao25
Mar 15, 2020Aspirant
E-mail Authentification fails RBR50
Trying to upgrade my firmware. Before getting there system asks for e-mqil verification. I do receive the emails with the sixfigure number, but upon entering the code I still receive the message that...
Mar 15, 2020Guru - Experienced User
Log in to the RBRs web page using the admin and PW you set up for the RBRs log in page at 192.168.1.1 or orbilogin.com
If you need to update, you can manually download and manually apply FW updates by downloading FW files from here.
https://www.netgear.com/support/product/RBK50.aspx#download
Use a wired PC and web browser for this.
Update the RBS first then RBR lastly.
Maomao25 wrote:Trying to upgrade my firmware. Before getting there system asks for e-mqil verification. I do receive the emails with the sixfigure number, but upon entering the code I still receive the message that the code is an error, pleae try again... amd again, and again...
