kncd
May 09, 2020Aspirant
Easy way to migrate from Orbi RBK20 to RBK50?
I have an Orbi RBK22 that I have used for a while, but wanted to add a satellite to it. I got a good deal on a RBK53 system, so I have decided to replace the RBK22 with it. Is there an easy way to move from one to the other (migrating configuration settings, etc.) or do I need to configure the authorized users/devices for RBK53 from scratch?
I'm a fan of configuring from scratch whenever I change primary routers.
Tends to have less issues down the line.
- kncdAspirant
Thanks. I was thinking that might be the best, just to make sure there is nothing still in the config that doesn't need to be there any longer. Since my android app is already associated with the RBK22, is there anything special I need to do to "disassociate" it with the RBK22 and associate it with the RBK53?
You can follow the "new system setup" through the app.
I'm not a huge fan of the app and usually setup via a pc. The install tends to go faster this route.
