RGT3
Mar 08, 2018Aspirant
Ecobee 4 Cannot Connect to WiFi
My Orbi has been having SEVERE issues lately. One of which is that is sees ecobee as a DOS attack according to the logs. It will not allow my Ecobee 4 to setup on the network.
the-reader
Jun 01, 2018Aspirant
I recently had a similar issue where Orbi showed the Ecobee connected to my satellite, the Ecobee showed it was connected as well just no internet connection. Ecobee also showed the signal strength at 75%, being 15ft away from the satellite that is just slightly down the hall in the office with door open (my setup has worked flawlessly for over 6 months together). When I would power off the satellite and the Ecobee would instantly connect to the main router, showing 95% signal strength despite being further from the Ecobee. I am not sure if the signal strength has anything to do with it but it's something I noted
I spent lots of time (mainly waiting) for Ecobee support to assist but they just kept blaming the router over and over again. I eventually found the setting "Enable Fast Roaming" under Advanced > Advanced Setup > Wireless Settings > check box at bottom of page. That instantly made my Ecobee start working.
For a test to see if this works for you, I would power off the satellite and see if the Ecobee connects to the main router and gets internet. Hope this helps!
Bboy486
Jun 03, 2018Aspirant
Do you know if this affects ring integration? This needed to be turned off for ring to work with orbi
