jamesnahon
Jul 31, 2019Initiate
Edit DHCP DNS servers - RBK50
Hi, Is it possible to manually configure the DNS servers given out by DHCP by the RBK50? I know you can change the DNS server for the route itself, I'm trying to configure the router to give out a ...
- Jul 31, 2019
Most NG routers including Orbi use a DNS proxy. Thus on the WAN side you can have the router use any custom DNS address. However for the LAN side, connected clients will always recieve the routers IP address for there DNS.
jamesnahon
That's sad to hear, but thanks for confirming.
Jul 31, 2019Guru - Experienced User
One thing about NG routers I wish NG would allow users to configure. :smileyfrustrated:
