gstar42
Feb 24, 2021Aspirant
email failed sending log RBK50
Orbi RBR50 Firmware V2.7.2.104 Win 10 Pro using Your Outgoing Mail Server: Outgoing Mail Server Port Number: My mail server requires authentication (checked) I get this: ...
CrimpOn
Feb 24, 2021Guru - Experienced User
gstar42 wrote:I'm sure I've entered the id & password correctly. Any suggestions? Any way to log what is actually being sent?
The mail server is smtp-mail.outlook.com and port number 587, correct?
I really wish more programmers would provide an option to see the actual password entered, rather than those stupid dots.
I frequently make typing mistakes with my long passwords and cannot verify them visually.
In the "old days", SMTP used port 25 and everything was sent as plain text. Capture the packets and learn all about it.
With today's SSL, everything is encrypted.
gstar42
Yes. That's the server & port #. It got erased when I pasted it in.
- CrimpOnFeb 24, 2021Guru - Experienced User
Searching for "Authorization failed (535 5.7.3 Authentication unsuccessful" turns up many hits, such as:
This is an existing account that "works", correct?
I actually set up a (free) GMail account specifically to send Orbi logs. Have never had a Hotmail account.
- gstar42Feb 24, 2021Aspirant
I tried a new gmail account, and my existing gmail account. Still getting
[email failed] ssmtp: Authorization failed (535 5.7.8 https://support.google.com/mail/?p, Wednesday, February 24, 2021 15:37:47
using smtp.gmail.com port 587
I even tried Less secure app access but it still doesn't work
- CrimpOnFeb 25, 2021Guru - Experienced User
I used port 465 for smtp.gmail.com, not port 587.
I think one thing that tripped me up was trying to send email from an account to the same account.
You have different account, correct?
