gstar42
Feb 24, 2021Aspirant
email failed sending log RBK50
Orbi RBR50 Firmware V2.7.2.104 Win 10 Pro using Your Outgoing Mail Server: Outgoing Mail Server Port Number: My mail server requires authentication (checked) I get this: ...
gstar42
Feb 25, 2021Aspirant
Also fails on port 465
CrimpOn
Feb 25, 2021Guru - Experienced User
I am just puzzled. I have two Orbi systems emailing log files to me. I (just personally) do not like the way Netgear presented the email form:
email account to go TO
smtp address of the sending account
smtp port of the sending account
login of the sending account
password of the sending account
Most of my other applications put the smtp address and smtp port after the sending email password and have the recipient after the sender.
My other apps often allow sending to more than one recipient.
- gstar42Mar 04, 2021Aspirant
Thanks for your help. Unfortunately it still doesn't work.
