ShankarHokie
Dec 30, 2020Apprentice
Email says Orbi RBR50 firmware update available. Checking from router says no new firmware
I got an email from Netgear that I need to update my firmware to enhance the security of my RBK53 system. However, when I check from the Advanced tab as instructed, I get the message that there is no...
Dec 30, 2020Guru - Experienced User
You can manually download and update if you want to. Or if your system is working fine, you can use whats working for you. Up to you. If you update, update the RBS first then the RBR.
