ShankarHokie
Dec 30, 2020Apprentice
Email says Orbi RBR50 firmware update available. Checking from router says no new firmware
I got an email from Netgear that I need to update my firmware to enhance the security of my RBK53 system. However, when I check from the Advanced tab as instructed, I get the message that there is no...
Wire1852
Dec 31, 2020Apprentice
I'm still at version 2.5.1.16 & don't plan to upgrade during the holidays. However when you do upgrade can you jump to the lastest version (or the one you feel is safe/stable) or do you have to do it in stages upgrading to version after current version installed untill you get to version you want?
You would think you could jump to version you want but at this point I how no confidence in Netgear based on how they have badly mishandled previous Orbi firmware releases.
- FURRYe38Dec 31, 2020Guru - Experienced User
You can go directly to the the lastest that avaiable ON NGs download site. If you do, be sure to update the RBS first, then RBR lastly. I went from v16, to v60 manually by downloading the FW files. v102 appeared on the RBRs web page after v60 was loaded on the RBS and RBR, so I used UPDATE ALL on the RBRs web page there and i'm now on v102 and is working well since loading it last week. No factory reset was performed since I didn't see any problems.
Wire1852 wrote:I'm still at version 2.5.1.16 & don't plan to upgrade during the holidays. However when you do upgrade can you jump to the lastest version (or the one you feel is safe/stable) or do you have to do it in stages upgrading to version after current version installed untill you get to version you want?
