janihiren's avatar
janihiren
Emails or websites (e.g. Macys, Kohls) won't download embedded images
Hello, I have recently bought CBR40 Cable Modem which replaced my ISP provided Modem/Router.  It worked fine but issue is that on my iPhone or on laptop can't see embadded images either from site or inside the email.
I am using wifi connection only.  Orbi connected straight to Coax cable and there is no middle router.
Any help would be appreciated.
Thanks.
  • FURRYe38's avatar
    Have you cleard all browser caches from the browsers on the phones then reconnect with web sites?
    Not getting images would be something with the mobile devices not handling the data correctly possibly.
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • janihiren's avatar
      janihiren
      I had to call support and they updated my DNS and it worked.  Thanks everyone for your reply.
