R_Garrett
Apr 18, 2020Aspirant
Enable Alexa Skill
Having trouble enabling Alexa NETGEAR skill.
- Apr 19, 2020
Not much to go on there.
What are you doing and where does it go wrong?
Is the A6150|AC1200 Dual Band WiFi USB Mini Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
michaelkenward
Apr 19, 2020Guru - Experienced User
R_Garrett
Apr 26, 2020Aspirant
I got it to work. Had to figure out how to register then was able to het to work. Thanks for the help.
