R_Garrett's avatar
R_Garrett
Enable Alexa Skill
Having trouble enabling Alexa NETGEAR skill.
  • michaelkenward's avatar
    Apr 19, 2020
    Not much to go on there.
    What are you doing and where does it go wrong?
    Is the A6150|AC1200 Dual Band WiFi USB Mini Adapter listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
