calworld
Dec 23, 2019Aspirant
Enable Orbi Guest Network at 5GHz
Is it possible to enable Orbi at 5GHz for guest network? I can see Orbi guest network only has 2.4GHz. I have a tenant that share internet with me so I want to seperate my network so I provided guest...
CrimpOn
Dec 23, 2019Guru - Experienced User
calworld wrote:Is it possible to enable Orbi at 5GHz for guest network? I can see Orbi guest network only has 2.4GHz.
The Orbi Guest network is both 2.4G and 5G. What has led to the conclusion that it is only 2.4G?
They both have the same Guest WiFi name (SSID), and devices connect to whichever channel gives them the best connection.
