calworld
Dec 23, 2019Aspirant
Enable Orbi Guest Network at 5GHz
Is it possible to enable Orbi at 5GHz for guest network? I can see Orbi guest network only has 2.4GHz. I have a tenant that share internet with me so I want to seperate my network so I provided guest...
SW_
Dec 23, 2019Prodigy
calworld wrote:Is it possible to enable Orbi at 5GHz for guest network? I can see Orbi guest network only has 2.4GHz. I have a tenant that share internet with me so I want to seperate my network so I provided guest network and not wanting to create another SSID.
You can check out this: How to enable separate SSID for 2.4 GHz and 5GHz on Guest Network.
CrimpOn
Dec 23, 2019Guru - Experienced User
I think the question was that there appears to be no 5G Guest network, which I think is incorrect. Not, how to create a different 5G network name. Guess we'll learn which it was when the poster responds.
- calworldDec 23, 2019AspirantI want to force a device to connect to 5GHz but it does not have that option. Therefore I suspect it only allows 2.4GHz. If what above reply is true that Guest WiFi does allow 5GHz, then how to I force it to connect to it?
- SW_Dec 23, 2019Prodigy
calworld wrote:
I want to force a device to connect to 5GHz but it does not have that option. Therefore I suspect it only allows 2.4GHz. If what above reply is true that Guest WiFi does allow 5GHz, then how to I force it to connect to it?Yes, you can do that with separate SSIDs on Guest Network. Check out my earlier post on how to do that.
- CrimpOnDec 24, 2019Guru - Experienced User
calworld wrote:
I want to force a device to connect to 5GHz but it does not have that option. Therefore I suspect it only allows 2.4GHz. If what above reply is true that Guest WiFi does allow 5GHz, then how to I force it to connect to it?This is where SW_ and I differ. He believes your device is capable of 5G connection, but fails to connect to the existing 5G SSID. I read your post to mean that the device has no 5G capability, and thus cannot be connected to 5G.
Maybe if you explain what the device is, we can look up the technical specs and give a better solution.
- calworldDec 25, 2019AspirantIt is a MacBook Pro
