dsc_dewain
Nov 28, 2016Guide
Enabling Guest Network
Has anyone tried the guest network yet? Couple of things I see. 1) When activating, I assume the router/satillite do some sort of reset, as my devices got disconnected during the process. 2) T...
wodehouse
Jan 05, 2017Aspirant
I have the WNDR4500v2 in the basement as my router to the world, and main switch on my network (wired and wireless). Upstairs I also have a Nertgear WAC120 access point. As noted, I powered that off during tests to isolate the symptoms.
rhester72
Jan 06, 2017Virtuoso
If you have Orbi in router mode connected to another router, you're double-NATting and guest will never work as intended. Orbi has to be the *only* router for isolation to work.
Rodney
