Drakier
Mar 23, 2019Aspirant
Enabling VPN on RBK50 causes internet to disconnect
I just got the RBK53 today and so far really like it and the features it has. I have it all updated and configured to work really well within my network and using hard-wired backchannel for satelites...
Sennevds
Jun 13, 2019Aspirant
I have exactly the same problem.
When I enable the vpn service on the orbi all clients on the private network have problems with connecting to the wan side.
The vpn client itself has no problems. My Orbi is behind another router(provider) so maybe it's a double NAT problem but still strange
- MavXDDec 10, 2019Aspirant
Hi, I have the exact same problem, internet connection is not working as soon as I switch on the VPN. Can anyone help?
Sennevds wrote:I have exactly the same problem.
The vpn client itself has no problems. My Orbi is behind another router(provider) so maybe it's a double NAT problem but still strange- ekhalilDec 10, 2019Master
- Will the issue start happening when enabling VPN or when you have a VPN client connected to Orbi?
- When you have a VPN client attached to Orbi, what IP address is assigned to this VPN client? You can check this by going to "Attached Devices" list in the bottom of the web GUI.
- What is the type and model of the ISP modem/router to which Orbi is connected?
- What LAN IP range are you using in Orbi?
- SennevdsDec 10, 2019Aspirant
- Happens when a client connects
- Need to check that
- A docsis 3.1 modem/router with 192.168.1.0/24 as range and the orbi set as dmz address
- 192.168.0.0/24 range
