Drakier
Mar 23, 2019Aspirant
Enabling VPN on RBK50 causes internet to disconnect
I just got the RBK53 today and so far really like it and the features it has. I have it all updated and configured to work really well within my network and using hard-wired backchannel for satelites...
Sennevds
Jun 13, 2019Aspirant
I have exactly the same problem.
When I enable the vpn service on the orbi all clients on the private network have problems with connecting to the wan side.
The vpn client itself has no problems. My Orbi is behind another router(provider) so maybe it's a double NAT problem but still strange
MavXD
Dec 10, 2019Aspirant
Hi, I have the exact same problem, internet connection is not working as soon as I switch on the VPN. Can anyone help?
Sennevds wrote:I have exactly the same problem.
- ekhalilDec 10, 2019Master
- Will the issue start happening when enabling VPN or when you have a VPN client connected to Orbi?
- When you have a VPN client attached to Orbi, what IP address is assigned to this VPN client? You can check this by going to "Attached Devices" list in the bottom of the web GUI.
- What is the type and model of the ISP modem/router to which Orbi is connected?
- What LAN IP range are you using in Orbi?
- SennevdsDec 10, 2019Aspirant
- Happens when a client connects
- Need to check that
- A docsis 3.1 modem/router with 192.168.1.0/24 as range and the orbi set as dmz address
- 192.168.0.0/24 range
Looks I can't edit my answer. I have found the problem.
It uses the same range as my isp router.
my client ip when connect to the vpn is 192.168.1.2 so in the 192.168.1.0/24 range.
The internet disconnect happens instantly(which is normal because of wrong range)
It looks you can't change which range the vpn clients have
- MavXDDec 10, 2019Aspirant
ekhalil wrote:- Will the issue start happening when enabling VPN or when you have a VPN client connected to Orbi?
1. Internet connection breaks down when aktivating VPN Server on RBR50. Connecting with a VPN Client to Orbi's VPN Server works.
2. IP address of client: 192.168.1.37
3. ISP modem/router is a Speedport w724v.
4. Orbi router uses IP range: 192.168.1.0/24
- FURRYe38Dec 10, 2019Guru - Experienced User
Can you ask the ISP to bridge your modem by chance? Would be helpful to get this modem bridged.
Have you tried putting the RBRs IP address it gets from the modems router into the modems DMZ yet?
