daponder
Apr 11, 2020Aspirant
equipment advice and local installer recommendation
Help? Our residence has a house with about 3,500 sq ft living space and a "carriage house/barn/office" that is about 100 feet to the north from the house and we have a boat pier that is also about 1...
CrimpOn
Apr 19, 2020Guru - Experienced User
daponder wrote:we do have an existing underground 4 inch conduit (for electric and plumbing) that would apparently allow us to fish ethernet cable through for a hard connection to do this as an option if necessary.
Would prefer to hire a local expert to do the work so we can save the monthly expense of the FIOS system in the barn?
Any local company that installs security systems should be competent to install an ethernet cable. There are code restrictions about placing electrical, plumbing, and communications. I am not confident that both electrical & communications (low voltage) wiring can be placed in the same conduit. In addition to code issues, it is generally not a good practice to have communications wiring close to and parallel to electrical wiring, even for short distances. 100 ft. seems "not a good idea."
Do you have a proposed solution for the pier?
daponder
Apr 19, 2020Aspirant
Thanks for the reply and YES, came to the same conclusion to NOT run the ethernet cable in the same conduit as the existing electrical. So will trench a separate conduit for the ethernet, coaxial and telephone lines to the barn/office . Found an ITS specialist who recomends Ubiquity Unifi products over Orbi and will set up the system components and then send to me with virtual hands on help. Includes UNifi POE Adapter, AC Inwall HD Office and outdoor Unifu AC for the pier/camera.
