Romans1136
Mar 16, 2024Guide
ERR_SSL_KEY_USAGE_INCOMPATIBLE
Hello ReneD
Can you tell me if there is anything in the works to address this issues (Chrome Certificate, etc) for the ORBI RBR50 / RBS50 mesh system?
I am happy to run thru steps, but canno...
- Apr 01, 2024
FYI, There is no patch for any Orbi AC series systems.
It's recommended if your seeing this issue is to use a different browser.
"If it is only about being able to enter the Orbi-menu of the Orbi-router, please use an alternative browser as a quick fix, for example: Firefox. Ignore the error message and to enter the Orbi menu/interface."
brian1918
Mar 29, 2024Aspirant
What would be the best way to be notified which Netgear release will have this issue fixed? My hardware is RBR20/RBS20, with fw 2.7.4.24. Thank you.
ReneD
Apr 03, 2024NETGEAR Moderator
Hello gcbmendham, brian1918,
Both RBK30 and RBR20/RBS20 are being handled by a different department. I will transfer you so they can give you the best answer for your queries.
Have a lovely day,
Rene D
Netgear Team
