PerdioB
Oct 11, 2023Aspirant
Error Message: Cannot Verify Server Identity
I have an Orbi RBR50v2 with the latest firmware. All of the sudden I started to get an error message saying "Cannot Verify Server Identity" on the iPhones connected to WiFi. Basically I have no inter...
- Oct 11, 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Oct 11, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
